Machine Vision
Invalid Coordinate System??
Thanks updated this is the bug list. Smiley Happy
Message 11 of 14
(3,215 Views)
CAR 441410 is also fixed in VDM 2014, but a bug fix is available and attached to the CAR.
Please contact NI support and ask for the file corresponding to the version of LabVIEW you're working with.
Message 12 of 14
(3,210 Views)
I have run into the same issue.  I have built a LabView VI (2014) using Vision Assistant 2014 and the VI works fine.  When I try to organize the VI into SubVIs I get an "Invalid Coordinate System" error.  I am certain that I have not broken any links or changed any names.  It seems as though there is a memory pointer that is lost. Does this patch work on Labview 2014 Vision 2014?  Is there some other work around?
-Bryan Joles
Message 13 of 14
(1,191 Views)
Hi, i'm facing the same issue with LabVIEW 2013 and I download the patch and everything... but still the same error...
Help please 😞
Message 14 of 14
(1,051 Views)
