You won't be able to convert your image into a 2D array from Vision Builder, but from what I read, everything you need to do can be accomplished with a simple LabVIEW program with IMAQ Vision. There is an example program on the Developer Zone that shows how to read an AVI file into several IMAQ Image files. That's probably your starting point. To find it, just type in "imaq avi example" into the search field of ni.com. Once you have the AVI file converted into several IMAQ Images, then you should be able to use the IMAQ Select Rectangle VI to allow a user to set a ROI. After that, just call the IMAQ ImageToArray VI to convert the ROI to a 2D array of pixel values. Or better yet, you can use the IMAQ FFT VI or any of the other Image Processing functions that come
with IMAQ Vision.
If you have any questions about the features of IMAQ Vision, please feel free to contact us at www.ni.com/ask.
Kyle V
