Hi guys
I've experienced a strange problem when using custom steps in VBAI 3.0.1. The problem is that I cannot use a reference to control anywhere within the VIs belonging to the custom step. When I do, it's not possible to insert the step into the script. The setup window closes immediately after it opens and the step is canceled.
When I test my step in VBAI from LabVIEW, everything works fine. The problem starts when the step is built for distribution.
I am attaching a custom step for demonstration. I have started with the template "Simple Processing Step". The only little change I've made is that I've inserted a reference to the "ROI Descriptor" control into "Ref Problem - User Programming.vi". However, the problem happens with references to any other control, even when used in the SubVIs.
Is this an expected behavior?
Vladimir
Message Edited by vdrzik on 08-27-2007 04:06 PM
