Machine Vision
Keep all overlay information during image acquisition when using the base IMAQ package
I have made an X control from the IMAQ image display control that has the ability to overlay points and lines on an image but when I put my X control into my image acquisition loop the overlay information disappears  with every new image I acquire.
How can I keep the overlay in place and just update the control with the new image and not overwrite the overlay data? I have tried the merge overlay function but this does not seem to work.
Thanks.
(5,014 Views)
Accepted by Jimmy01
Overlays normally are erased when you acquire a new image.  You could create the overlays on a separate image, then copy the overlays to each new image before you display it.  The other option is to recreate the overlays for each new image.
Bruce
Bruce Ammons
Ammons Engineering
(4,995 Views)
Ok thanks looks like I will create the overlays each time inside the Xcontrol so.
Thanks!
(4,975 Views)
