Machine Vision
LabVIEW doesn't detect USB 3.0 Basler Cameras
Hi EveryOne,
im using a basler USB 3.0 Cameras but LabVIEW Doesn't detect it
can anyone help me ?
thanks
Message 1 of 10
(8,046 Views)
Accepted by topic author mon3am
Do you have Vision Acquisition installed? http://www.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:du,n8:13.79.7820,ssnav:n...
Can you see and use the camera in NI-MAX?
Message 2 of 10
(8,021 Views)
Hi rrobe,
the cameras was using Pylon basler Driver .
i changed it using MAX
thanks
Message 3 of 10
(7,886 Views)
please let me know how to switched from the pylon drivers to MAX. The Basler camera is visible in NI MAX, but the Labview program cannot detect it.
Thanks.
Message 4 of 10
(4,898 Views)
Look at the attached image in the post above yours which shows how to change the driver.
-AK2DM
Message 5 of 10
(4,892 Views)
Oh, got it. Thanks a lot.
Message 6 of 10
(4,883 Views)
MAX indicates that I should change to NI-IMAQdx, but I don't get the option.
In the past I have used this camera in LabVIEW, but I'm not completely sure if it was on this computer, or my previous one.
Message 7 of 10
(2,798 Views)
I found another topic with the same issue I have (Windows 11 related).  This can be discarded.
Message 8 of 10
(2,794 Views)
Hi !
I do have exactly the same situation I think. I can see the Basler camera in the tree, but I have an error message when I click on it, and then, if I right-click on it, no item is active, so that I cannot choose any driver.
Did you fix the issue?
Message 9 of 10
(2,204 Views)
So, I have just received a BASLER AC640-750uc and it works well in their pylon software. Managed to get the driver switched in NI-MAX but it shows no image
Message 10 of 10
(592 Views)
