Machine Vision
Line following using vision
Hi guy ...
How can I follow a line using Vision and obtain reports for sending them to somewhere ?
For example a black line in the white color area.
What is the best method ?
Any help would be greatly appreciated.
Thanks in advance!
(9,506 Views)
Do you mean overlay? You can use overlay line.
(9,494 Views)
overlay ?
No. I want to track a black line in my picture. "line tracking"
plaese see the attachment ...
What is the best method ? Color matching ? Edge detection ? Template matching ?! ....
I don't have any idea.
(9,479 Views)
The easiest way in your case probably: Threshold->Skeleton->Extract coordinates (with MaskToROI, for example), something like that:
VI in attachment.
Andrey.
(9,467 Views)
Hi Andrey ...
Can you explain program further more ? (specially inside While Loop)
Can we use Vision Assistant instead of using IMAQ VIs ?
Which is better ?
Which perform faster (execution time) ?
Please explain your experiments.
Thanks in advance ...
(9,437 Views)
Inside of while loop: calculation of bounding box (+- 10 pixels around point), then draw circle for visualization of the tracked line. Follow the line
point by point
Which is better ?
Using Vision Assistant will be quite complicated, because you will be unable to get all coordinates from the particle easily. Otherwise you can do it probably with your own VI. You can't compare LabVIEW with Vision Assistant - they are completely different.
Because Vision Assistant based on the same vision libraries - they absolutely equal from performance point of view.
Hmm, I guess, the given example wasn't soo complicated...
Below explanation:
Sorry, can't explain more detailed...
Andrey.
(9,434 Views)
Hi!
Good idea for solving this mentioned problem!
Do you have maybe any idea how could we set a starting point where alghorithem would start with moving along the line.
Best regards.
(7,769 Views)
