Machine Vision
Losing trigger to camera with FPGA 8254R
Hi to everybody,
I'm getting a very serious problem I don't now how to overcome...
We collect images to be analyze using NI PCI-8254R board and LBV8.5 with Vision Dev 8.5.  I have 2 AVT 1394 Guppy cameras running in Mode 1 trigger. Our process get 3 images/sec and we run geometric match on it.
The system works in this way:  I have two inductive sensors looking for the parts coming, when the parts arrive a high signal is forward on the IsoInput 5 or IsoInput 8 of the FPGA and the FPGA should send a pulse signal over TTL Pulse 1 or Pulse 4 to the correct cameras for the trigger and getting the image.  The procedure is clearly shown also on NI documentation..
Everything works well for 97% of the time (hundreds of images)...but sometime randomly the FPGA receive the trigger but will not send the pulse...and I miss the image...
Useless to say I check everything already...the sensors, the cables, the cameras, the power...everything works well, without noise.
I tried to skip also all image process and later on also grap process...just the simple routing..and sometime we miss it..  WHY?
We checked if it was a point of pulse width and delay that maybe it was to long for the frequency of signal routing, but even with loo frequency (3 parts/sec) sometime we miss the signal..
It could be 8254 FPGA has a problem running two process in parallel? Maybe FPGS sleep sometime??Smiley Very Happy
Using an oscilloscope, we saw a ratio between width and missing signal with high frequency (over 6-7 parts/sec), but we can't understand why we miss also the first image, sometime and not running 1-3 parts/sec....
I attached a simple test I did to check the routing...I also change two 8254 cards, and the problem still appear...
I thank you very much for any comment and suggestion... My brain is gone on that....
I need to solve this issue and I cannot miss one image in this process.
Marco
(3,667 Views)
Hi Marco,
here at NI-Italy we are facing a similar issue with one of our customers. We're performing some tests to verify if this could be an HW issue related to the board itself or if we can provide a workaround for this.
I'll reply to you as soon as possible with new informations,
Fabio
Fabio M.
NI
Principal Engineer
(3,643 Views)
Hi Fabio
Is there any progress on this issue?
Vladimir
View my profile on LinkedIn
(3,513 Views)
Hi Vladimir,
i have to speak with the guy here who dealt with this issue. I'll reply to you as soon as possible,
Best Regards,
Fabio
Fabio M.
NI
Principal Engineer
(3,494 Views)
