Machine Vision
Lost "IMAQ Vision Example Folder.vi" file
Hi everyone,
I was working with this file and I lost it. Now I couldn't find it or repair it also I re-install all the vision modules, and many of the examples use this file to take the path of the images to work. Can anyone help me trying to search the file path and bring me the IMAQ Vision Example Folder.vi
I appreciate your collaboration,
John
(6,289 Views)
the .vi is located at (for Labview 2013):
C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\Vision\IMAQ Vision Example folder.vi
If you reinstall Labview (Vision) the missing file should be restored.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,281 Views)
Accepted by JOHNJGM
Hi, thanks for your answer, but I did that and I don't know why didn't work. I solve the problem using the IMAQ Vision AVI Folder.vi and modifying the block diagram and deleting some parts, and then rename it as the vi that I lost. In that way, I solved the problem.
(6,273 Views)
