07-13-2007 12:25 PM
07-13-2007 02:14 PM
07-16-2007 03:14 PM
07-31-2007 09:59 AM
07-31-2007 10:10 AM
ImageToImage should be in all the versions of Vision. I think it has been around a while.
Look under Vision Utilities -> Image Management to find it. The icon has a small box with an arrow pointing to a larger box.
Bruce
07-31-2007 10:17 AM
Hey Bruce,
Under Vision Utilities > Image Management I have 10 VIs.
IMAQ Create, IMAQ Dispose, IMAQ Image Bit Depth, IMAQ Get Image Size, IMAQ Set Image Size, IMAQ Get Image Info, IMAQ Read Custom Data, IMAQ Write Custom Data, IMAQ Get Custom Keys, and IMAQ Remove Custom Data.
I'll try looking elsewhere for it though...perhaps through the installation it was relocated.
07-31-2007 10:22 AM
07-31-2007 01:30 PM
08-01-2007 02:48 PM - edited 08-01-2007 02:48 PM
Message Edited by Steve.Briggs on 08-01-2007 03:48 PM
08-01-2007 05:17 PM
Steve,
You used the same name for all three images. When you use the same name, only one image is created and it is reused. You need to create three different images with three different names for it to work properly.
Bruce
