Machine Vision
NI 1429 Speed Via DLL
We have a camera that is capable of the full 921,600 baud listed in the Camera Link spec. Can the baud rate capability for the 1429 frame grabber go above the listed 115,200 if we will be using the DLLs to access that hardware?  Hopefully that method will go a little faster.
Thank you,
Jordan
(3,090 Views)
Hi Jordan,
Unfortunately, no you will not be able to go above the listed 115,200 for the 1429 framegrabber. Using the DLL won't make a difference since the Grab function essentially makes that call for you with negligible overhead.
(3,068 Views)
