Machine Vision
NI 8252 and PC firewire port comparison
Just wondering about the performance diffrance and other advantages we get by using firewire NI  8252 frame grabber
insted of reqular PC firewire port !! any advices please?
Best Regards
MyKat
(3,032 Views)
Depending on whether your computer has a 1394a or 1394b controller, there could be an advantage to using your computer. With most firewire ports, they have a single host controller and all ports share bandwidth though that host controller. 1394a is limited to 400Mb/s while 1394b is 800Mb/sec. The 8252 is a 1394a card so if your computer is 1394b, the 8252 will actually have less available bandwidth. On the other hand, if you are already using multiple firewire devices, adding a 8252 could add another host controller which means you would have that additional bandwidth available.
-Zach
(3,009 Views)
