Machine Vision
NI-IMAQ hardware compatibility
Are there any hardware vendors that make Expresscard 34 or 54 cameralink frame grabbers that are compatible with NI-IMAQ?  I see that NI only makes PCIe frame grabbers (not something that could be easily used with a laptop).
(3,937 Views)
Hi ApersonNumber3,
Our NI IMAQ drivers only support National Instruments frame grabbers. Do you already have the camera you'll be using?
Cheers,
Andy C.
(3,920 Views)
