Machine Vision
NI-IMAQdx : I can't get a flow rate higher than 100Mbps in MAX with a IEEE1394b camera under Windows 7 32bits
I am using a AVT Pike F145B or F210B camera. These are IEEE1394b cameras.
When I use MAX (version 4.6.2), I only get a flow rate of 100Mbps in the drop-down menu.
I already had a similar issue under Win XP sp2 and sp3 and the solution had been to change value in the register. Is it the same under win7 ?
(3,947 Views)
Windows 7 has a re-written FireWire driver that natively supports 800Mbit operation out-of-the-box with no modifications. Is it possible you ran some driver tools to enable 800Mbit operation provided by the camera vendor designed for XP/Vista? Those should be unnecessary on Windows 7 and might cause problems...
Eric
(3,933 Views)
Microsoft messed up 1394b in XP SP2, SP3, and Vista, and finally got it right again in Windows 7.
For XP and Vista users, AVT developed a replacement driver that overcomes the Microsoft 1394 driver problem:
http://www.alliedvisiontec.com/us/products/software/windows/avt-1394-busdriverpackage.html
For Windows7 users, 1394b cameras should operate at full S800 rates (assuming so configured in camera settings...).
Scott
(AVT)
(3,931 Views)
In fact I have the same problem with a IEEE1394a camera : I tried an AVT Dolphin F-145B.
I also installed up-to-date version of NI VISION Acquisitio Software ... with no success ...
Any other ideas ?
(3,913 Views)
I forgot to add that I tried using my cameras with AVT SmartView and it works fine : I can choose the frame rate (up to 400Mbps: I only have IEEE1394a on my computer).
(3,912 Views)
How about Window 7 64bit?
I can't install the AVT program at Window 7 64bit.
Anybody know the solution for WIn7 64bit?
(3,640 Views)
On Windows 7, the out-of-the-box 1394 OHCI driver shipping with Windows supports all the 1394a/b speeds correctly with no special drivers needed.
Eric
(3,637 Views)
