Machine Vision
NI Smart Camera Infrared Blocking Filter
I'm looking for dedicated IR blocking filters for the NI 1752 Smart camera. I had no luck finding any online.
The filter needs to block heat radiation emitted from steel at 1100F.
Any input is appreciated.
-Hazim
(4,300 Views)
Accepted by hsalem
The 1752 uses a C-mount lens, so you should be able to add a lens filter that is compatible with a C-mount.
Aaron L.
Applications Engineer
(4,281 Views)
