Machine Vision
NI-Vision Acq. Examples and VIs not present after install
I'm using a PCI-1405 card to capture video from a Photon 320 IR camera. After installing the software I tested the camera functionality using the Measurement and Automation Explorer. The driver and software appeared to have installed correctly as I was able to grap and record video in MAX. When using Labview however, no IMAQ examples are present. One of a couple NI examples I was able to manually find include IMAQ VIs that are not present. I've tried reinstalling the NI-Vision Acquisition software but that does nothing. Does anyone know how I can add the missing VIs. They all appeared to be standard IMAQ VIs
(3,263 Views)
Could you post the version of LabVIEW you are using and the versions of your driver software?  It is possible the driver software does not have support for the version of LabVIEW you are using.  It is also possible the support is available, but for some reason is not getting selected during installation.
During the install of VAS, there is a screen which shows which parts of VAS are going to be installed.  One of these parts is support for LabVIEW.  Run the install and see if your version of LabVIEW is supported by that version of the driver and make sure that the support is selected.
(3,257 Views)
hello jumgonza,
I also faced a similar issue recently. I had labview 8.6 but the vision acquisition system/software was 8.5 which did not have support for labview 8.6.
Your problem should be solved by installing a supported version of VAS.
Sandeep
(3,242 Views)
