Machine Vision
set template options with vision development module
hi,
i have a created a Geometric Template in my C#-Application.
Now i want to give this Template the necessary  options
The current problem is that i get no error message when i save the template with the vision infos, but when i use it to search a picture, the template isn't found.
this is my method (i know it's a bit much code, but i don't know what you need):
CWIMAQLearnGeometricPatternOptions TemplateOptions = new CWIMAQLearnGeometricPatternOptions();
            string FileName = Application.StartupPath + @"..\..\..\..\Templates\" + TemplateName.Text + ".png";
            if (comboExtractionMode.Text == "Normal" )
                TemplateOptions.CurveOptions.ExtractionMode = CWIMAQExtractionModes.cwimaqExtractionModeNormal;
            if (comboExtractionMode.Text == "Uniform Regions" )
                TemplateOptions.CurveOptions.ExtractionMode = CWIMAQExtractionModes.cwimaqExtractionModeUniformRegions;
            if (comboExtractionMode.Text == "" )
                MessageBox.Show("Choose an ExtractionMode!" ) ;
            TemplateOptions.CurveOptions.Threshold = (int)System.Convert.ToSingle(EdgeThreshold.Value);
            if (comboEdgeFilterSize.Text == "Fine" )
                TemplateOptions.CurveOptions.FilterSize = CWIMAQEdgeFilterSizes.cwimaqEdgeFilterFine;
            if (comboEdgeFilterSize.Text == "Normal" )
                TemplateOptions.CurveOptions.FilterSize = CWIMAQEdgeFilterSizes.cwimaqEdgeFilterNormal;
            if (comboEdgeFilterSize.Text == "" )
                  MessageBox.Show("Choose an EdgeFilterSize!" );
            TemplateOptions.CurveOptions.MinLength = (int)System.Convert.ToSingle(MinimumLenght.Value);
            TemplateOptions.CurveOptions.RowStepSize = (int)System.Convert.ToSingle(RowSearchStepSize.Value);
            TemplateOptions.CurveOptions.ColumnStepSize = (int)System.Convert.ToSingle(ColumnSearchStepSize.Value);
             axCWIMAQVision1.LearnGeometricPattern(Create_Viewer_Template.Image, TemplateOptions, Create_Viewer_Template.Image);
             axCWIMAQVision1.WriteImageAndVisionInfo(Create_Viewer_Template.Image, Application.StartupPath + @"..\..\..\..\Templates\" + TemplateName.Text + ".png", Create_Viewer_Template.Palette);
i hope somebody can help me
Message Edited by kumi on 12-18-2008 09:18 AM
Message 1 of 11
(6,369 Views)
Im creating an application using c# also, maybe I can help you. Sometimes its a pain to use the VB.net examples as a reference coz some function parameters in VB.net cant be of the same signature in C#...especially when C# forces you to use out and ref keywords. VisualStudios intellisence is of great help for me...
Anyways, Whats the error message your getting?
Did you use the ReadImageAndVisionInfo function before using the template?
Riscoh
Message 2 of 11
(6,360 Views)
hallo,
first happy new year and sorry that i'm a bit late to respond, but i wasn't here over the holidays.
So to the error-message i get:
"invalid geometric matching template image."
But i don't understand why.
In my oppinion i have set all the right template options....
And yes: i used ReadImageAndVisionInfo to load the Template File into the program.
kumi
Message 3 of 11
(6,281 Views)
I have encountered the same error message with color pattern matching and it turns out the images are not of the same type.
LearnGeometricPattern and MatchGeometricPattern uses U8 images as per imaq help file might wanna double check.
Riscoh
Message 4 of 11
(6,273 Views)
thanks for the advice.
i tried it with this function:
Create_Viewer_Template.Image.Type = CWIMAQImageTypes.cwimaqImageTypeU8;
but i don't know where to use it.
i tried it in the method
 - when i save the template
 - when i load the picture from which the template is made
 - when i extract the template in another viewer
where have you put it?
Message 5 of 11
(6,208 Views)
MatchGeometricPattern Method
You also have to change the image type of the image you are tying to inspect not just the template
SearchImage.Type = CWIMAQImageTypes.cwimaqImageTypeU8
CWIMAQVision.MatchGeometricPattern(SearchImage, Template, MatchGeometricOptions, GeometricPatternMatchReport ,  Regions)
If the image you are trying to inspect is already loaded onto the viewer you can change the type like this
viewer.Image.Type =  CWIMAQImageTypes.cwimaqImageTypeU8 before calling the MatchGeometricPattern function
It would be better to post your code where you have the MatchGeometricPattern function so I could try and figure out whats going on with your code....
Message 6 of 11
(6,201 Views)
i´ve tried your advice but it didn't worked Smiley Sad
here is my code (i put the whole method here, don't know what is really important for you):
private void MatchTemplate_Click(object sender, EventArgs e)
            Match_Viewer_Picture.Regions.RemoveAll();
            CWIMAQMatchGeometricPatternOptions MatchOptions = new CWIMAQMatchGeometricPatternOptions();
            CWIMAQGeometricPatternMatchReport MatchReport = new CWIMAQGeometricPatternMatchReport();
            CWIMAQRegions Regions = new CWIMAQRegions();
            MatchOptions.CurveOptions.ExtractionMode = CWIMAQExtractionModes.cwimaqExtractionModeUniformRegions;
            MatchOptions.CurveOptions.FilterSize = CWIMAQEdgeFilterSizes.cwimaqEdgeFilterNormal;
            MatchOptions.MinimumMatchScore = (float)System.Convert.ToSingle(MinMatchScore.Value);
            MatchOptions.NumMatchesRequested = (int)System.Convert.ToSingle(MinNrMatches.Value);
            if( Occlusion.Checked)
                MatchOptions.MatchMode = CWIMAQGeometricMatchModes.cwimaqGeometricMatchOcclusionInvariant;
            if (Rotation.Checked)
                MatchOptions.MatchMode = CWIMAQGeometricMatchModes.cwimaqGeometricMatchRotationInvariant;
                MatchOptions.RotationAngleRanges.Add(1);
                MatchOptions.RotationAngleRanges.Initialize((int)System.Convert.ToSingle(RotatedMin.Value), (int)System.Convert.ToSingle(RotatedMax.Value));
            if (Scale.Checked)
                MatchOptions.MatchMode = CWIMAQGeometricMatchModes.cwimaqGeometricMatchScaleInvariant;
                MatchOptions.ScaleRange.Min = (int)System.Convert.ToSingle(ScaledMin.Value);
                MatchOptions.ScaleRange.Max = (int)System.Convert.ToSingle(ScaledMax.Value);
            Match_Viewer_Template.Image.Type = CWIMAQImageTypes.cwimaqImageTypeU8;
            Match_Viewer_Picture.Image.Type = CWIMAQImageTypes.cwimaqImageTypeU8;
            try
                axCWIMAQVision1.MatchGeometricPattern(Match_Viewer_Picture.Image, Match_Viewer_Template.Image, MatchOptions, MatchReport, Regions);
            catch (Exception ex)
                MessageBox.Show(ex.Message, ex.Source, MessageBoxButtons.OK, MessageBoxIcon.Error);
            Match_Viewer_Picture.Image.Overlays.Item(1).Clear();
            for (int i = 0; i < MatchReport.Count; i++)
                DrawGeometricPatternMatch(Match_Viewer_Picture.Image.Overlays.Item(1), MatchReport.Item(i+1), System.Drawing.ColorTranslator.ToOle(System.Drawing.Color.LawnGreen));
            MatchesFound.Text = (String)System.Convert.ToString(MatchReport.Count);
kumi
Message 7 of 11
(6,188 Views)
Could you also post the images(template and the image to be inspected) I'll try and create an application to see if we get the same result...
The only potential problem I see on the code is there are no regions although you defined a CWIMAQRegions object but it doesnt contain any  CWIMAQRegion object. CWIMAQRegions object must contain exactly one rectangle or one rotated rectangle region as per help file...
But I doubt if you would get this  "invalid geometric matching template image."  error message if there arre no regions defined.
Riscoh
Message 8 of 11
(6,174 Views)
hello, i attached the pictures & the class with my methods
Message 9 of 11
(6,161 Views)
Ive tested the images on Vision assitant and the template didnt work I created a new template using the default values and it worked right away
You get this "invalid geometric matching template image." error message when you try to inspect an image using a template that does not contain enough features for geometric matching...
try use the template Ive used and see what happens... Also I would suggest to just use pattern matching for this application coz I think the results are more repeatable...
and forget about the image type the viewer defaults to U8 images...
Riscoh
Message 10 of 11
(6,148 Views)
