Machine Vision
Need a 45 day evaluation activation of IMAQ vision
I have an urgent need to evaluate the IMAQ vision and Analysis Assistant software(s) for my present
MX12P camera/PCI-1422 hardware. Downloaded the Analysis Assistant for 45 days eval. Downloaded
the IMAQ for also 45 days eval (extended). But unable to activate it in evaluation mode. Can
you send temp code for activation???
My management wants to buy the software if I can demonstrate soon that it works.
Larry Teresi
Sr Test Engineer
Compound Photonics
480-620-1362 cell
(4,368 Views)
The best thing to do would be to conact your local field sales engineer:
http://www.ni.com/domestic_sales/usa.htm
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,364 Views)
Hi Larry,
Another option would be to call NI Support and ask for an extended eval license.
Elmar
(4,357 Views)
Hi Larry,
There is unfortunately an issue with automatically extending your 7-day evaluation license to 45 days through the Vision software itself. This was reported to R&D (CAR # 381293) for further investigation. For now, the above suggestions should be able to get you an extended evaluation license, or you can try through this link: https://delta.ni.com/extendedevaluation/index.xhtml?p_lang=US
(4,353 Views)
