Machine Vision
Need help with VBAI and shift register
Is there a way to "shift" each string variable result from a specific step (for example, "0101") 5 times in a stack fashion before it is finally fed to the serial port on each iteration in VBAI 3.6 or higher? Without using a LabView vi ?
(2,918 Views)
Ok i just found out that the solution was right there. Thanks anyways.
(2,911 Views)
