Machine Vision
Negative Image
still new to IMAQ. Which IMAQ function or combinations of functions can I use to get the negative of an image. In MATLAB it is simply imadjust(Image,[0 1], [1 0].
Also, is there any function to get intensity slicing.
Thank you.
(5,763 Views)
Hi okogidi,
you can use the "IMAQ Inverse" function.
Mike
(5,755 Views)
Hi okogidi,
You can look at the subPalette Vision and Motion>Machine Vision>Measure Intensities for intensity calculations.
--Michelle
(5,734 Views)
