Machine Vision
Supported frame grabbers
Does imaq support Imagenation frame grabbers?
(3,218 Views)
No.  IMAQ is only for NI framegrabbers and generic interfaces like firewire and GigE.  NI does not create drivers for other framegrabbers.
However, if you use the drivers that come with the card, it is frequently possible to bring the images into LabVIEW.  Once you have them in LabVIEW, you can manipulate them using the Vision module.
Bruce
Bruce Ammons
Ammons Engineering
(3,210 Views)
Thanks for the info....
(3,207 Views)
