Machine Vision
No IMAG VIs in Motion & Vision Sub Pallets
I had installed LabVIEW 6.1, NI-IMAG 2.5.2, Advanced IMAG Vision for LabVIEW 6.0.1, and IMAG Vision Builder 6.0. I also installed IMAG-PCI-1409 board. The video capture board is functional.
However, when I tried to create a vision application, I could not pick out any sub VI for IMAG from the Motion & Vision sub Palette. The only sub VIs I could see were the Flex Motion & Value Motion sub VIs. What would be missing? Please help. Thanks.
Daniel Tran
danieltran@micro-analog.com
(3,035 Views)
Daniel,
Which did you install first, IMAQ or LabVIEW? If you installed the IMAQ software first or if you did not specify to install support for LabVIEW 6.1, then the VIs would not have been installed for your system. Try going into Add/Remove Programs from your Windows Control Panel and then choose to modify the installation of "NI Software." Then select the IMAQ 2.5.2 drivers and choose to change that installation. Navigate through the custom installation screens until you come to a point where it asks you what software support you want to install. Be sure that LabVIEW 6.1 has been selected and that support has been installed on the local drive. If the problem persists, try uninstalling and reinstalling the IMAQ drivers and be sure to install LabVIEW support.
Try those steps and let me know if you have any additional questions on this issue.
Scott R.
Scott Romine
Course Development Engineer
(3,024 Views)
