‎03-09-2010 02:09 AM
Hi all!
In LV 8.6 there is an example : Nonlinear Calibration Example.vi (coins). I would like to do the same in Vision Assistant.
First, I found and loaded the calibration grid, created a nonlinear template
opened the coin-image, and when I select: Calibration from image this message appears:
"The file you selected does not contain valid calibration information"
Could anyone help me?
Solved! Go to Solution.
‎03-09-2010 02:25 AM
See the help
Applying calibration information from one image to another
Note The size of the calibrated image you select must be the same size as the image you want to calibrate.
Calibration from Image (Image»Calibration from Image)
Applies the calibration information saved in an image to the current image.
Defines physical dimensions of the area of a pixel in the image and the correspondence between pixels and real-world units.
Defines a reference coordinate system in the image.
‎03-09-2010
02:29 AM
- last edited on
‎06-15-2026
08:20 AM
by
Content Cleaner
Also see this lv example [link removed; example no longer available]
‎03-09-2010 03:59 AM
Hi! Thank you for your fast reply. I have started to develop, after calibrated the grid, and saved it, tried to use this grid calibration (calibration from file) on nonlinear coin - image. I recieved a message : "calibration information is not valid"
What do u think, what the problem could be, if I use the same images like LV8.6 example.
‎03-09-2010 04:15 AM
‎03-09-2010 07:54 AM
‎03-09-2010 07:56 AM
‎03-09-2010 07:58 AM
‎03-09-2010 08:06 AM
