Machine Vision
Not seeing value of any function in calculator
Hi, please help me,
I using a function pixel count in my inspection. In a main window i can see a count of pixels, which is 171698. But if I try to debug calculator function, the value is 0,00E+0. Any idea why the values are not the same. Thank you dor any helping answer
(4,728 Views)
in general there is a big difference between editing and running calculator step. Values of controls coming from previous steps are not automatically updated (while creating calculator step). You need to click "compute results" button on the Measurement tab to force update of inputs . After that you will be able to debug your code with proper control values.
Ondrej K.
NIEE AE
CLA, CTA, CLED
(4,700 Views)
