Machine Vision
Vision Acquisition Block does not open Wizard
I'm trying to use the Vision Acquisition block but it just does not open the settings window/Wizard.
The block Vision Assitant opens normally.
However, if I open a .vi that had the Vision Acquisition configured, it compiles, but will not let me see their properties, settings, nothing. Also, if I double click on it to try to open it undoes the previous links. The LabView seems to try to load something, but in the end nothing happens. I have already reinstalled Vision Acquition and nothing. And the license is ok. In MAX, the camera that I want to access appears functioning normally.
Any suggestions?
(4,273 Views)
Wich version of LabVIEW and wich version of the Vision Development Module are you using?
Frank
(4,230 Views)
Having the same problem. I am using the Student version of both. I can go into Vision from tools but when I place a vision acquisition block in vi nothing happens. Can not see properties etc.
(3,623 Views)
Sorry using student version 14, the latest. Also when I go to properties I do see the creating vi measage then nothing.
(3,622 Views)
