10-29-2005 02:56 PM
10-31-2005 02:08 PM
Hi Jaime,
Vision Assistant will allow you to load .tif, .bmp, .png, and .apd images. Assuming your scanner can save images as one of these formats, you will be able to load the image into Vision Assistant. In order to perform OCR, you will need a 8-bit or binary image. If you have a color images, there are several options to convert to 8-bit or binary images including extracting a color plane and thresholding. Once this processing has been performed, you will be able to run OCR.
Ryan M.
Applications Engineer
