Machine Vision
OCR reads correctly in Vision Assistant but not Labview
When I read the characters in vision assistant the system rarely has a false read.  However,in LabVIEW with the same exact file it makes 30%-40% bad reads.  I am not sure what I am doing wrong.  I have attached an image for you to look at.
THANKS!!!
JJ
(4,282 Views)
Quick question, JJ...
Was the LabVIEW code generated with Vision Assistant?  If so, have you changed the code, or the regions of interest?
Chris Bolin
LabVIEW Partner Program, CLA
(4,258 Views)
The code was not originally generated with Vision Assistant but I have copied most of the parameters over "directly".  I have been extremely carefully tomake sure the parameters are the same but itispossible there isa small difference.  I am pretty confident the code is the same.
JJ
(4,256 Views)
One quick troubleshooting step would be to generate a LabVIEW VI from Vision Assistant.
You can do this to your existing Vision Assistant OCR script by going to Tools » Create LabVIEW VI
Message Edited by CXB on 09-17-2008 10:29 AM
Chris Bolin
(4,246 Views)
I will second the recommendation.  I have seen several cases where the default values in Vision Assistant do not match the default values in LabVIEW.  Duplicating all the options that you have access to in VA is not enough.  It is much better to use Create LabVIEW VI to get an exact copy of all the settings used.
Bruce
Bruce Ammons
Ammons Engineering
(4,232 Views)
Thanks Bruce!
Chris Bolin
(4,219 Views)
THANKS FOR YOUR HELP!!!
I will be at the customer next week and will try a few of these items.
JJ
(4,209 Views)
