09-15-2008 01:58 PM
When I read the characters in vision assistant the system rarely has a false read. However,in LabVIEW with the same exact file it makes 30%-40% bad reads. I am not sure what I am doing wrong. I have attached an image for you to look at.
THANKS!!!
JJ
09-16-2008 06:21 PM
Quick question, JJ...
Was the LabVIEW code generated with Vision Assistant? If so, have you changed the code, or the regions of interest?
09-16-2008 07:08 PM
The code was not originally generated with Vision Assistant but I have copied most of the parameters over "directly". I have been extremely carefully tomake sure the parameters are the same but itispossible there isa small difference. I am pretty confident the code is the same.
JJ
09-17-2008 10:28 AM - edited 09-17-2008 10:29 AM
One quick troubleshooting step would be to generate a LabVIEW VI from Vision Assistant.
You can do this to your existing Vision Assistant OCR script by going to Tools » Create LabVIEW VI
09-17-2008 08:56 PM
I will second the recommendation. I have seen several cases where the default values in Vision Assistant do not match the default values in LabVIEW. Duplicating all the options that you have access to in VA is not enough. It is much better to use Create LabVIEW VI to get an exact copy of all the settings used.
Bruce
09-18-2008 02:49 PM
09-18-2008 11:28 PM
THANKS FOR YOUR HELP!!!
I will be at the customer next week and will try a few of these items.
JJ
