Machine Vision
Object length measurement
hi friends
I have to work on vision based project to measure the length of the object.In this project  camera position is not stable,and  zooming also varied ,this case how to make accurate distance measurement.?
now I developed the edge detection method to measure distance between two points .but if zoom is changed ,its wont give proper value...
so pls tell me what steps I need to do..
expecting your replay.. 😕
Raj
(5,188 Views)
Accepted by Pandiyan
It is impossible to measure something accurately if you are changing the zoom on the lens unless you have a reference included in the image that can be used for calibration.  The only way to do it is to calibrate the image at known zoom positions and only use those positions.
The distance between the part and the camera is also an issue.  If the distance is changing, the calibration factor changes just like the zoom.  If the distance isn't fixed you need to calibrate at multiple distances and only place objects at those distances.  The only way to make distance not matter is to use a telecentric lens.
Bruce
Bruce Ammons
Ammons Engineering
(5,170 Views)
 Hi BRUCE Thanks for your reply.i am also suspect that.but now you clarified me .
Raj
(5,167 Views)
I have been working for some time with high resolution Acama, with adequate lighting and digital zoom I can get 1mm menorahs measures, the automatic zoom was a problem but manually configure the vision assistant
(4,947 Views)
if still not solved the problem you can measure distance passing an RGB image to 8bit and extract a color plane insert VERTICAL CLAMP IMAQ function MIN which will measure the minimum height of the piece analyzed, this function block can be located within the MACHINE VISION path / MEASURE DISTANCES
(4,946 Views)
