Machine Vision
Opening a jar file using labview
I want my labview program to open a java based jar file on my computer after some processing steps...there is no manipulation of the jar file to be done..It just needs to be opened...Anyone has any answers?????
(5,516 Views)
Hi Prathiksha,
Check this https://forums.ni.com/t5/LabVIEW/how-to-use-jar-file-in-labview/td-p/1821711
and http://digital.ni.com/public.nsf/allkb/BEE812007BA2A9B486256BC80068A49A
uday
(5,513 Views)
hello,
well i did breeze through them.......it looked complicated Smiley Sad.......the sites specify in implementing the java classes in labview or to modify them.......but my jar file is a standalone kind............it just has multiple frames with buttons that help to switch between the frames...more of a gui.....i need labview to open it at an appropriate time so that i won't have to do it manually.......is that possible or do i have still have to make a dll file out of it??????
(5,506 Views)
It seems that you do not get the right attention here. Note: This is the Vision forum and your initial message has a view count of 12  Smiley Sad
Proposal: Start a new thread in the LabVIEW forum. Good luck.
(5,502 Views)
Hi Prathiksha,
As GuenterMueller said, this forum subgroup is dedicated to Machine vision queries and not related to general software queries. Please post your query in Labview Forum or some other appropriate location.
Coming to ur problem, infact even i've seen that java interfacing all those are really compicated and am afraid i dnt know about that.
uday
(5,492 Views)
Thank you.....i will.....hopefully my problem will have a solution
(5,489 Views)
