Machine Vision
vision_acquisition
I use LabView 2011 on Windows7 machine, I have installed Vision Acquisition Software correctly in my machine, and when I open a project I recibe a Error list with IMAQdx....vi errors. I tryed to reinstall and reapir Vision and the problem continues happening. The project works ok in other machine with the same LabView version. Can anyone help me with this?
Thaks.
(5,339 Views)
Hi ToloV,
Looks like problem with installing vision acquisition module. In the block diagram, please check in the Vision-> IMAQdx->do you've vis like IMAQdx Grab,snap??
If not, try reinstalling vision acquisition module and don't forget to install the driver dvd also.
uday
(5,334 Views)
Did you verify in the Release Notes (screenshot below) that the version of the Vision Acquisition Software supports LabVIEW 2011?
Which version of VAS do you install?
(5,331 Views)
Sorry for my misrelated screenshot in the previous mail:  The Release Notes will just tell you the minimum version of LabVIEW that will be supported.  All current versions of the VAS support LabVIEW 2011.  So the only chance I see that you don't get IMAQdx support in LabVIEW 2011 is installing a version of the VAS that is too old.
(5,328 Views)
you need to install the NI IMAQdx device drivers (device drivers dvd).
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,320 Views)
