Machine Vision
PCI 1407 can do line scan
HI
I have PCI1407 board and PULNIX TM-200 camera. I need analyze one object that is very highest . Can PCI1407 board  do line scan?
(2,809 Views)
The 1407 is a framegrabber board that is most often used with standard format analog cameras.  The Pulnix TM 200 is a standard analog camera.  I do not believe that you will be able to do linesan acquisitions with this hardware.  If you were to acquire an analog linescan camera, I believe there is a camera file that should allow you to proceed with this method.
Good luck on your application,
Robert
(2,798 Views)
