The 1407 is a framegrabber board that is most often used with standard format analog cameras. The Pulnix TM 200 is a standard analog camera. I do not believe that you will be able to do linesan acquisitions with this hardware. If you were to acquire an analog linescan camera, I believe there is a camera file that should allow you to proceed with this method.
Good luck on your application,
Robert
