Machine Vision
(PCI 1424) Cable for 1 SCSI 100 Pin connector to 3 IDE 40 Pin connectors required
I have a PCI 1424 frame grabber (LVDS). I need to connect it with my Kodak imager board (KLI-14403 Evaluation board). The board has 3 IDE Connectors each having 40 Pins.
Can anybody suggest me a cable that can connect 100pin SCSI connector (on PCI 1424) to my imager board (having 3 IDE 40 pin connectors)?
(3,522 Views)
I haven't specifically worked with interfacing between the 1424 and and your Kodak imaging board, but it doesn't appear that there is an NI supported cable that can interface between the 2.  This will most likely require custom cabling, I'm hoping perhaps there are some other users that have already done this who can help.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,510 Views)
