06-11-2006 03:27 PM
06-12-2006
06:25 PM
- last edited on
10-07-2026
03:25 PM
by
Content Cleaner
Hi Air Force 1,
How are the other programs reading the image data, as a PNG file or as a 2D array of values? I know that LabVIEW saves a 12-bit image as a 16-bit image (the next largest bit depth) where the pixel values use signed 16-bit integer values (I16). Other programs may save and view 16-bit image data as unsigned 16-bit integer values (U16). Let me know if this is not the information you're looking for.
Cheers,
Irene Chow
Applications Engineer
06-18-2006 03:47 PM
06-20-2006
06:59 AM
- last edited on
10-07-2026
03:26 PM
by
Content Cleaner
Hi Air Force 1,
What version of NI Vision are you using? I found a KnowledgeBase article [link removed; article no longer available] that may describe your situation precisely, and it says NI Vision 6.0 corrected the issue. Let me know if this helps.
Irene Chow
06-20-2006 12:36 PM
06-21-2006 12:24 PM
Air Force One,
Please Zip the files or change their individual extensions to attach to this thread. Also, if you open the images with Windows Picture and Fax Viewer?
Scott Savage
Applications Engineering
www.ni.com/support
06-21-2006 04:10 PM
06-25-2006 02:20 PM
