Machine Vision
Particle Orientation Modification
I'm trying to modify ni's Particle Orientation Example, so I'll be able to extract additional data from it.
I've tried to modify the "unbundle" function in the loop for the new data, but it's impossible to extend the "unbundle" tool.
Any suggestions?
Thank you,
(4,652 Views)
You can use a reshape array and convert it into a 1d array
20201i48375303A83DE0BF
(4,639 Views)
***Double post***
20203i12ABEFC7CA60BFC5
And if you want to unbundle it and use it you can also avoid the for loop
(4,638 Views)
Thanks for your approach Muks, but will I still need the analysis and the option to choose the background (i.e... white on black, black on white, and etc...). So I think I still need the for loop for that, don't I?
(4,630 Views)
Also, just for curiousity, why do they subtract 25 from the x center of mass in the example (inside the for loop)? I wonder if an ni person could answer that.
(4,627 Views)
Accepted by simply_me
You have define your own cluster size in array to cluster. Right click the array to cluster and define the same.
20211iCF188636C535A19E
(4,610 Views)
The 25 is subtracted so that the numbers can be overlayed in the image properly. Change the number to say 100 and you will change the overlayed test to change. The 25 is subtracted from the centre of mass x.
(4,609 Views)
