Machine Vision
Particle analysis- Cannot understand Sum X, Sum XY, moment of inertia XY
I want to know what does Sum X, Sum Y, Sum XY , Moment of inertia X, Moment of inertia XY etc mean?
I looked up at the document here but did not find it useful. It just shows a table!
Does anyone know what it represents and how they are calculated?
Also an intuitive explaination would be great to understand quickly.
Thank You.
Regards
Aveo
(5,667 Views)
they are calculated as is shown by the equations you've provided.
A hint:
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,657 Views)
Hi Klemen,
Thanks for your insights. The vi helped me to understand the calculations performed to obtain the sums and moment of inertia.
Also I composed a small vi of my own which helped me to understand a little further.
I am attaching it with this post.
I have summarized my learning in the comment of the vi.
Thank you,
Regards
Aveo
(5,653 Views)
Hey..Thanx for putting this VI over here...
I also got idea of how to calculate SUM's .I want to know where i can use this?Is there any specific task where it is require?
Please also share how calculation of moment of intertia has calculated and what is use of it?
If you have any document regarding this it is appreciated
Again Thanks ...!
(4,559 Views)
