05-18-2015 01:03 AM
I have this little program which finds multiple patterns but i have a problem with the IMAQ Read Image And Vision block. It give me this error "error -1074395995".
I put the right path of the patterns folder but still the same error. Can someone help me?
Best regards.
05-18-2015 01:22 AM
05-18-2015 01:32 AM
I don't know how to put a probe at that terminal 😄 can you help me or describe in detail how to to do that?
Best regards.
05-18-2015
01:42 AM
- last edited on
08-12-2025
04:25 PM
by
Content Cleaner
Create a new vi, Drag this image into labview block diagram.
Run the vi and take screenshot of what the path indicators are giving and post.
To use probe, while the vi is running, you need to go that wire and right click and you should be able to see probe window...for more
https://www.ni.com/docs/en-US/bundle/labview/page/using-the-probe-tool.html
05-18-2015 02:08 AM
This is the result
05-18-2015 02:09 AM
The result
05-18-2015 02:19 AM
05-19-2015 11:04 AM
After many attempts i've solved that problem but now i've got discove another problem :
Error -1074395628 occurred at IMAQ Learn Multiple Geometric Patterns
I creeated my template with NI Vision template editor from Vision Assistant and my VI still not recognize my template from my folder.
Any help?
Thanks a lot.
