Machine Vision
Problem in the code for detecting the components on the PCB image.
I am working on a code to detect whether all the trained components are present on the PCB or not.
I am using the quantum camera and vision acquisition software in labview to capture the image of the PCB to be tested. Then the image is compared with the original PCB image which is having all components.
I had written the code and it is working only at some instances. I can't understand what the problem really was. Please help to know what the problem was and also help me by specifying the requirements like camera pixel, surrounding effects when the image was being captured, camera options like ZOOM, distance of the object from the camera.
Thank you
(3,754 Views)
for starters I suggest reading:
http://zone.ni.com/reference/en-XX/help/372916M-01/nivisionconcepts/setting_up_your_imaging_system/
And in my opinion, you should (in the future) describe the problem more thoroughly and in detail. There is not enough information in your explanation.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(3,729 Views)
