Machine Vision
Problems in Calibrating Distortion
The input of this for-loop is a bundle of images, and its corresponding dot-coordinates. (Using the
d "IMAQ Calibration Target to Points - Circular Dots 2"). The for loop updates the parameters of the camera using all the images, however, its only on the last iteration, the last image, when it learns the final values. So the equal sign within the for-loop specifies when there is no more images to learn from. The output of this VI (Image Out), contains all the calibration information, and can by used in the "IMAQ - Learn Distortion Model".
Message 11 of 11
(670 Views)
