‎01-04-2008 10:57 AM
‎01-04-2008 01:00 PM
‎01-04-2008 03:19 PM
Thank you for pointing me in the right direction. I looked at the firmware and found this in the GigE Vision Release Notes:
"...Known bugs and limitations: Currently the Programmable Logic Controller is not exposed thru GenICam so to enable external trigger signal you will have control the PLC by using the non-GenICam method (Click on Select and pick the approriate camera then click on Connect instead of 'use GenAPI')...."
It seems I must connect to the camera "using the non-GenICam method". But when I power on my camera, MAX connects to it automatically.
Question: Does anyone know how to control the way MAX opens/connects to the camera?
‎01-04-2008 03:39 PM
‎01-07-2008 01:41 PM
Eric,
Great advice! Thanks alot. That is exactly what I needed to do. I contacted JAI and they emailed the latest version of the firmware that is not even released yet. I now have access to my camera's PLC.
Thanks again!
~Dewey
