08-18-2009 06:09 PM
Hello, I'm trying to use a Pulnix RM-6740GE, dated 6/10/09 with LabVIEW. LabVIEW is having trouble interfacing with the camera. I try to view an image through NI-MAX first and it returns a error 0xBFF69012 - attribute out of range. The camera works find with the JAI tool software so I believe its not an ethernet interface problem. Can you shed any light on what may be causing the problem? Thanks, Bruce Barnes Coherent Applications Inc.
Solved! Go to Solution.
08-19-2009 02:01 PM
I suggest checking with JAI regarding your camera's firmware to make sure that it is compliant with the GigE Vision standard. If necessary, you should be able to download the GigE Vision compliant firmware from http://www.jai.com/EN/CameraSolutions/Download/Pages/Cam2NetSW.aspx.
08-19-2009 05:12 PM
Hi Bruce,
Is there any more text associated with that error- specifically,which attribute is out of range? This would help with troubleshooting.
08-19-2009 05:52 PM
I have found and fixed the problem. I noticed that my versions of NI-IMAQ and NI-IMAQdx were not the current versions so I updated them. Then I deleted the .iid and .icd files for the camera. I cycled the power on the camera, launched NI-MAX and the camera was working properly. I then continued to my vi and the camera preformed perfectly!![]()
Bruce
