Machine Vision
RGB to HSI COLOR SPACE transfer
Can some body help me by example how to change the color space from RGB image to HSI image  and then save and display the new image
Message 1 of 8
(6,705 Views)
Do you want to extract  a single plane? you can use "extract color planes". Do you want a conversion then
I = 1/3(R+G+B)
S= 1 - 3/(R+G+B)  [ min of R,G,B]
            -1
H = cos     [1/2 [(R-G) + (R+B)]
                  sqrt[(r-g)^2 (R-b) (G-B)
Message 2 of 8
(6,703 Views)
thanks a lot for your answer, but I would like to get an bloke digram function examples if that possible even if that as pictures.
meftah
Message 3 of 8
(6,700 Views)
Do you have vision assistant installed?
Message 4 of 8
(6,698 Views)
Thanks alot for your answer but, unfurtunate I dont have the vision assitant. Just I would like to show what I did in order to get your feedback and the correct vi
Message 5 of 8
(6,694 Views)
I have lv 8.0. Can you post it for 8.0? or a screen shot of your block diagram?
Message 6 of 8
(6,669 Views)
Thanks alot for your interest, I already post them into LV 8.0
Colorchange VI is methode to change the RGB image to HSI image for special image processing. Actually I buld this code base on the other code which I attached also. plz look at them and try your best to get the correction
my best regars
Message 7 of 8
(6,664 Views)
Accepted by Meftah2000
Message 8 of 8
(6,662 Views)
