Machine Vision
ROI's that VBAI creates in labview have different sizes to those in VBAI?
i am using VBAI 2.5 to generate my inspection which i am then migrating into Labview 7.1, can anyone explain why the ROI's which are setup in labview are not the same to those in VBAI? and is there a solution other than manually going through all the generated labview code to updat the roi's?
(3,344 Views)
Hi Stewbert,
Another soloution you should try is upgrading your LabVIEW to LabVIEW 7.1.1.  This is a free upgrade availavle from
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/6c5f342a4af4ef8986256f5400693c3b?OpenDocument
This may fix your problem
(3,332 Views)
unfortunatly upgrading to labview 7.1.1 didn't help.
(3,312 Views)
Hi S, This is a known issue in VBAI 2.5. It looks like there was an underlying problem with how the image dimensions were being read in VBAI. A 640x480 image was not necessarily being interpreted that way in the software. So when the code is ported to LabVIEW, the dimensions for the ROIs are based on the incorrect image size. For the image in LabVIEW, the correct image dimensions are used, so the ROIs are shifted. The end result is that VBAI 2.6 addresses that issue and repairs the problem. . Seamus
(3,294 Views)
