Machine Vision
how do i open vision assistant script in vision builder?
is it possible to covert script developed in vision assistant 7.1.1 to vision builder 2.0?
(4,749 Views)
You can use existing Vision Assistant scripts by adding them as steps in your Vision Builder AI inspection.
- Create a new Vision Builder AI inspection or open an existing inspection
- Add a Vision Assistant step
- Within the Vision Assistat window, select File >> Open Script and navigate to your saved script (.scr)
Brent
(4,735 Views)
unfortunatly the version of vision assistant that the vision builder step uses does not have the full functionality of vision assistant. i.e. there are none of the machine vision guaging tools available.
(4,729 Views)
Vision Builder AI contains a version of Vision Assistant that contains only the image processing functions (functions that modify the image). You can access other functions like edge detection, pattern matching etc directly from Vision Builder AI.
-Christophe
(4,695 Views)
right, i've re-written all my scripts in VBAI, however when converting the script into labview code the ROI's dont stay in the same place! (there is another thread running on this problem)
(4,614 Views)
Hi S, refer to http://forums.ni.com/ni/board/message?board.id=200&message.id=6911 regards, Seamus
(4,601 Views)
