Machine Vision
Remove Block Area from Rotated Image
I am doing a project on Image Registration.
I used phase correlation technique to calculate the translational parameter.
I also got the rotation angle of the image using "IMAQ Find Pattern.vi". But my problem is when I rotated the image in opposite angle to recover the rotation it pads block area (Pads zeros)(to avoid information loss). So when I used that image for phase correlation it gives wrong results because of that block area.
Please download the attachement " Test_Images.zip " before analyzing my problem.
'Original.jpg' is the original image.
'Part_1.jpg' is the part of the image taken from 'Original.jpg'
'Original_30.jpg' is the rotated version of 'Original.jpg' (30 degree in Clockwise direction).
'Rotate_30.jpg' is the part of the image taken from 'Original_30.jpg'
'Part_1.jpg' And 'Rotate_30.jpg' have some common part (Near the wheel of the car).
Using 'IMAQ Find Pattern.vi' , I am able to get the rotation angle.
I Used 'IMAQ Rotate.vi ' to nullify the rotation of image (Rotate_30.jpg) to register with the first image (Part_1.jpg) (i.e Rotate 'Rotate_30.jpg' -30 Degree OR 30 Degree in anti clockwise direction)
'Recovered_30.jpg' is the result of 'IMAQ Rotate.vi ' operation.
But as we can see in the image 'Recovered_30.jpg' the above said operation pads 'Black Area' to the rotated image.
So while attempting to register images (Part_1.jpg and Recovered_30.jpg) it gives error.(i.e I am getting wrong result).
So I want to remove that black part from the 'Recovered_30.jpg' image.
Please help me to solve this problem.
If you have any other idea please let me know
Thanking you
AKSHARA.T.G
(3,375 Views)
Can you please post the attachment? There was not one as part of the original post.
Satish
(3,338 Views)
