Machine Vision
Write Character Set File
Hi, this is my 1st time on this forum. I have some doubts about the function "IMAQ OCR Write Character Set File". Does this function save in the selected path all the property set during the training phase? I.e. the "acceptance level" or the "read resolution"? Does it save the mode and the threshold values too?
Then, could I use the "IMAQ OCR Read Character Set File" to load all the property?
Thanks a lot.
edo.
(3,438 Views)
Yes. IMAQ OCR Write Character Set File will write all of the properties during the write. IMAQ OCR Read Character Set File will read back the properties.
Satish
(3,354 Views)
