Machine Vision
Remove Particles that overlap?
I'm looking for an efficient  way to remove particles from my binary image that are overlapping.
Image 1 is the current thresholded frame
Image 2 are the particles that are bad
Image 3 is the combination of image 1 plus image 2
I want to remove the particles that are "overlapping"
Any efficient ideas?
Branson
PS Images are in binary form, so you need to open them in IMAQ to see them.
Red = binary value 1
Green = binary value 2
Blue = binary value 3
image 3 in color
(4,580 Views)
Do you mean you want to remove the red particles that are touching green particles?
Bruce
Bruce Ammons
Ammons Engineering
(4,570 Views)
Accepted by Branson
I guess you are trying to do a binary reconstruction, have a look at the IMAQ Binary Morphology Reconstruction: https://www.ni.com/docs/en-US/bundle/ni-vision-labview-api-ref/page/imaqvision/imaq_binarymorphology...
Provide the function with your "bad image" as the marker image.
Hope this helps
Regards
(4,562 Views)
I want to keep the particles that are only red, and I want to remove the particles that have green or blue.
(4,558 Views)
Thanks toto69!
IMAQ Binary Morphological Reconstruction
Wired Image 1 to Image Source
Wired Image 2 to Image Marker
Result was any particle from image 1 that touches the particles in image 2.
From there, I IMAQ Or'd Image 2 with the Result,
Image 4 - Reconstructed
and then subtracted that result from my original Image 1.
Awesome!!
(4,553 Views)
