Machine Vision
Rename USB Camera Resource Name (IMAQdx)
Hi All
I am facing issue while after successfully renaming USB Camera resource name (IMAQdx) through LabView Programmatically by changing content of .iid file and its name.
Issue is New name doesn't appear after using  Imaqdx Enumerated Camera.vi (Showing old name),after restarting LabView application New name appears.
Is there any way to get new name (through Imaqdx Enumerated Camera.vi) without restarting LabVIEW application ?
(In MAX we don't need to restart application after renaming Camera name.)
I tried out System Configuration APIs but it doesn't allow me to rename IMAQdx USB resources.
Thanks.
(1,681 Views)
Have you solved the problem? I have the same problem
(1,018 Views)
