Machine Vision
Restore Camera Target Image in VBAI
I'm using Vision Builder AI 2012 with Smart Camera NI1772C.  I can create Target Image of the camera (Menu>Target>Create Target Image) but is there a way to restore the image back to the camera?  Is the image similar to PC back up image which can be safely stored then restored in case of emergency?
(5,729 Views)
Accepted by bwv1043
Once you have created the target image, you can update any similar model target with that image. Launch VBAI and from the splash screen, select the target to update, and right click on the target and select "Configure...". On the last step of the configuration, you can browse to the zip file containing the image you made to restore the target with all the files from the image.
Hope that helps,
Brad
(5,724 Views)
Hope that helps,
Brad
(5,723 Views)
I just could not find the restore feature myself.  Thanks for your help.
(5,718 Views)
Hope that helps,
Brad
Thanks for your detailed instructions.
(5,496 Views)
