Machine Vision
Run Smart Camera without Computer
  What's the procedure for running a Smart Camera without a PC?  I'd like to power it on, and have it automatically run.  The software was developed on the camera itself, and it outputs pass/fail signals in a continuous loop.  But if I don't have the program brought up on the host PC, or if the ethernet cable is disconnected, it won't run--although the IMG ACQ LED does blink as though it were running a program.
  I have a 1722 Smart Camera.
(3,534 Views)
Accepted by jblc
Hi jblc,
Assuming you developed your inspection in VBAI, the following KB should outline how to get it to automatically run on startup.
How Do I Set My VBAI Inspection to Run at Startup On My CVS, EVS or Smart Camera?
http://digital.ni.com/public.nsf/allkb/F79D691691FE564A86257141007A1B93?OpenDocument
(3,523 Views)
